So I read all the other posts and started the install today...
I thought from reading the posts, you guys didn't have to cut your stock rubber lines. That doesn't seem to work for me though. The outlet of the radiator is right in front of this part of the frame, so the stock line has this 90 degree bend to it...(I have a push-in fitting screwed on to it and stuffed a rag in the opening so bugs won't go in there since I left it like that in the driveway)
But the B&M kit only comes with straight fittings that screw onto the radiator here...
They don't fit because the push-in end of the fitting hits the frame. I went all around town looking for a 90 degree version of the fitting the B&M kit comes with, but no luck at all. The guys at NAPA said they only have 3 in the whole country and they're in Seattle. Should I just cut the original rubber hose (1st pic above) and get a push-in fitting to a push-in pitting to connect 2 rubber hoses?
