crazy4mopar
- Poway Ca,
I have a 242 in my 89. The problem is in 4 low the gearing is reduced to the rear wheel but the front axle keeps popping out of 4low(only the rear spins). I was told to change the linkage bushings (they were toast) because the linkage was not letting it get all the way into 4 low because of too much slack in the bushings. So I changed them today adjusted the linkage.......Still won't lock in. I was also told the synchros were going bad and also told the chain may be skipping...... Any ideas where to start? :dunno:
Thanks,
Thanks,
