XJ_ranger said:I know that the stock tailcone design changed.
The 95 and older t-cases have the old style tailcone with the seal
that seals on the slip yoke and the 96+ t-cases have a seal on the
mainshaft.
Yucca-Man said:My understanding is that most of those parts lists (and quite a few folks on) think that the t-case didn't change until the body style changed in '97. I haven't seen anything to indicate that the '96 NP231 tailcone assembly is any different than the 97+
If there were, more than likely they would have answered by now.falcon556 said:There has to be somebody on this forum that knows.
RCP Phx said:What is it you "really" need to know?
Yes,the most likely issues would be changes in the wiring connectors.falcon556 said:What I need to know is: Can I grab a 97+ and make it work in my '96?
What do I need to change if anything to make it work?
That's all I need.
RCP Phx said:Yes,the most likely issues would be changes in the wiring connectors.
Eagle said:You are regarding an interchange book as a definitive source, and they are frequently incorrect. Call a dealer and ask if the 96 transfer case has a different part number than a 97 transfer case. I think they are the same.
