Track bar bracket suggestions
Forceful Llama
MOdesto
So I am about to swap in a hp30 into my xj and I am currently using RE 1600 track bar that's mounted single shear to the frame side bracket. The axle I plan to swap in has a Kevin's offroad double shear and would really like to run it. My problem is I do not have the frame side bracket for Kevin's and they said they don't usually sell it separate from the bar. What other aftermarket brackets would work with it? I've considered Clayton and T&T. Just curious if they would work
RE, Clayton, etc. If you do not get/find one right away you can run it in single sheer for the time being. If anything, you might need "spacers" or washers to make up the difference of the misalignment spacers or find wider ones.
Iron rock off road
Clayton or RockKrawler as they use big hardware and are made well anything else is a joke unless you can make one.
You could check with Ironman to get his adapter. You would then need to drill out your bracket and weld the thing on after you get it all ligned up.
Both are running a dbl shear TB. One came with the new frame side mount (forgot brand, beefy) the other is Ironman's design using the adapter and the factory mount. For me, the Ironman design is way more ridgid than replacing the entire mount. No noticable flex at all.
http://ironman4x4fab.com/Products/TB.html
a KOR trackbar will never fit inside a RK bracket. the thing is tiny, RK uses their own heims for it, i couldnt get a ruffstuff one in there. that being said, i have like 40k miles on that heim and bracket on two different jeeps without a problem.
Thanks for the suggestions. Couple here I had forgotten about. In the end I might try running Clayton or t&t. Ill post up a picture when I swap the axle in the next couple of weeks and use Kevin's offroad trackbar.
