- Las Vegas, NV
Demco Excali-bar.
$275.00 OBO
Uses 7/8" diameter pin. Same size as the clevis most of us carry. The one mount on the bumper used for recovery can double for towing.
Comes with two different Silent Hitch Pins. One is straight, the other gives either a 3" lift or a 3" drop depending on which way it is installed. The photo above shows the 3" lift configuration.
Contact: Andy [email protected]
or (818) 584-6057
Currently located in Las Vegas but MJR can take in back to Southern California with him on Sunday.
$275.00 OBO
- Gold sealed lock collar is sealed to keep out dirt grime and moisture allowing easier movement and less maintenance.
- Patented quick release tool.
- 10,500 lbs. maximum towing capacity when used with appropriate weight rated 2" receiver.
- Solid stainless steel connecting arms.
- 4-position storage lock. Folds to either side and rides neatly on the bumper when not in use.
- Storage rods for coiled electrical cable.
- Coiled safety cables included.
- Silent Hitch Pin. Stabilizes your solid shank to your receiver giving you a solid, noise free, theft deterrent towing system.
- Self-supporting arms. The tow bar arms are easy to hook up because they don't drop to the ground.
- No ball & coupler. The tow bar attaches directly into the receiver with the Silent Hitch Pin.
- Automatically adjusting. One man operation.
or (818) 584-6057
