Torx (star bolt) sizes?
Sarge
St Louis, MO
Been thru my manual a few times and it either aint here or I've missed it every time....looking for the star bolt size for the pass side fender bolts and the door bolts on a 1993 XJ.
Sarge
t20 should be the size without running outside to look. If you don't own a set of Torx sockets, get them they are all over the XJ's. Juice
Going by memory here but I think the door takes a T40 or T45. I have the smaller Lisle set from Sears and it's close to the biggest one in the set.
I think the fender ones are T28 and the fromt ones for the grill are like T30, I think the T25 will strip out the fender bolts. And you will most likely have to replace some, they like to strip the threads on the insert.
