Engine Mounts—Rear
Crossmember-to-Sill Bolts (Automatic) . . . . . . . . . . . . . .41 N·m (30 ft. lbs.)
Insulator Stud Assembly Nut . . . . . . . . . . . . . . . . . . . .41 N·m (30 ft. lbs.)
Support Cushion/Crossmember Nuts . . . . . . . . . . . . . . . . . .22 N·m (192 in. lbs.)
Support Cushion/Bracket Nuts (Manual) . . . . . . . . . . . . . . . .75 N·m (55 ft. lbs.)
Transmission Support Bracket Bolt (Manual) . . . . . . . . . . . . . . . .46 N·m (34 ft. lbs.)
Transmission Support Bracket/Cushion Bolt (4WD Auto). . . . . . . . . . 75 N·m (55 ft. lbs.)
Transmission Support Adaptor Bracket Bolts (2WD Auto) . . . . . . . . . 75 N·m (55 ft. lbs.)
Has some weird language in there, i'm guessing support cushion is the actual mount, hope this helps have fun deciphering WTF they are trying to tell you.
