canadianwheeler
- canada
I get a very load rattle from near my torque when my xj is in gear. In neutral or park it makes no noise. Any clue? Somthing loose?
Hmm, sounds kinda like what mine is doing right now. Does yours only rattle when you're completely stopped and in drive then go away as soon as you start driving again?canadianwheeler said:I get a very load rattle from near my torque when my xj is in gear. In neutral or park it makes no noise. Any clue? Somthing loose?
Big DaveXJ said:Hmm, sounds kinda like what mine is doing right now. Does yours only rattle when you're completely stopped and in drive then go away as soon as you start driving again?
Eagle said:.......you can do that just by removing the inspection cover. QUOTE]
I don't know much about tranny and such. What/where is this inspection plate? Is it the 1/16" (or there abouts) sheet metal bolted "in front" of the tranny, where in one corner a exhaust pipe hanger plate is bolted?
Thanks _Maz
Big DaveXJ said:Ha, yeah I figured that out right after I posted. All of the bolts on the flywheel were very tight and it was not cracked yet I still get the rattling, could this be the actual torque converter going bad? When I put a wrench on the flywheel bolts to make sure they were tight, as I tried to tighten them I was able to rotate the entire flywheel, seems to me that it should not be so easy to rotate the entire crank from the flywheel bolts ( I thought you had to do that by putting a breaker bar on the harmonic balancer), is this a bad sign? 89 XJ 4.0 185k miles.
Grizzley said:You have more leverage with a wrench on the convertor bolt than you do with a breaker bar on the harmonic balancer bolt.
I should have been more explicit. Have been in your situation before and it isn't a lot of fun though.Big DaveXJ said:When I put a wrench on the flywheel bolts to make sure they were tight, as I tried to tighten them I was able to rotate the entire flywheel, seems to me that it should not be so easy to rotate the entire crank from the flywheel bolts ( I thought you had to do that by putting a breaker bar on the harmonic balancer), is this a bad sign? 89 XJ 4.0 185k miles.
