Took the plunge. Finally cut my fenders.
mako my day
Aliso Viejo
Now I need bigger tires.
It actually feels great. Now no more rubbing or tearing up my meat.
I think it was souske that originally called me a puss for not wanting to do it.
Nice, did you use the sawzall?
I used a handheld jigsaw with a fine blade.
my cuts weren't perfect, but there was a lot of adult beverages involved, so that may have contributed.
I used some sort of fender trimming that I got from Mark (sharkXJ) to clean it up. can't remember where he got it.
IMO jigsaw/airsaw/sawzall makes the fender jump around too much and you end up with a really rough cut and warped fenders. cutoff wheel and patience will give you the best final outcome.
This is what fellow naxja members are for.
I cut while another one held the fender in place
Also, the use of a fine blade and high speed on the jigsaw makes it much less likely to jump around.
I did it my first time with a cutoff wheel. It works OK, except that it burns the paint off and it is a much bigger PITA to follow a line with sparks flying everywhere.
doesnt burn the paint at all if you do it right. like i said, the trick is to clean it up with a flap disk. i usually just rough it out within 1/4" with the cutoff wheel, then take the rest down with the flap disk. it's real nice for doing smooth contours. I've done a few with factory paint and zero paint damage.
Body saw is the way to go. Quick like a sawzall. But more precise and controlled.
