TNT longarms/RC crossmember
1sicto
TN
Ok guys I need ya help. I have a 1997 xj runnin 5.5 RE COILS WITH ACOS spacers up front & 4.5" leafs with adjustable shackles & relocation brackets. I ordered tnt longarms to mount up to the RC longarm crossmember to have proper diff alignment. My issue is the ball ends are 2 5/8 from tnt(too big) & 2 1/2 has a lil slop(too small). So what do I need to do here? The ball end from RC is alot smaller so want work with tnt arms. Do I use washers or shims(prob not) or can I order another set of ball ends that fit?
Use the much better TNT crossmember. I have no idea what your referring to about the "diff alignment"?
I'm aware of quality between the two but the question was if they made a exact ball size that will fit both rc crossmember & tnt arms?
