jragan
- Colorado Springs
I know a stupid question 35's of course... Here is my setup and before I go much futher I want to throw some thoughts around... I am currently running about 6.5 " of lift, 4.56 gear (do not think other mods matter for info I am looking for). The Cherokee is going to be flat towed behind the truck with cabover camper. A number of the trips we make doing this will be for wheeling however we will still have those trips that are not. Thinking the use of the Jeep will be for my wife's 6 mile (round trip) commute as it is currently used, and when camping might run 30-50 miles down the highway for site seeing or to get to a trail. I am have searched and found a ton of info back and forth on which tire size to go with, however wanted to talk with Colorado folks that actually deal with the altitude and real hills\mountains.
So... 4.56 and 35's running down the highway, do able? Flat towing bigger tire vs. smaller tire?
Also do the
events limit tire size on trail runs. Currently running 32's and need to know if I should look at tires before Colorado Fest (more then likely just be up for a few days) and also Oct in Moab. I do not want to be limited however if I go 33's the 1/2" ground clearance is not buying me much so would rather run the 32's down and do a long arm.
Also do the
