- Camden, SC
A little more back story. On the day I was driving to Fla, I noticed the temp was running about 20deg higher then normal. it went about 150 miles like that before it spiked enough to make the Check Gauges light come on. Then after a mile or so it would go back down to where it was (around 220). I thought maybe the thermostat was sticking. I stopped at a gas station and removed it, permatexed it back on. It stayed around 210 while idling so I headed back down the road. After about 20 miles it did it again.
It will stay around 210 while idling but once I get up to 60+ for 10 mins or so it will go up to 225 or so and stay there for a bout 10 mins then spike again.
I gave up and called AAA and had it towed to Savannah where we could rent a car.
It really seemed like a head gasket / head issue from the symptoms. And the fact that these 00-01 engines are known to have head issues, I felt like that was the issue.
So this past Saturday, I ended up going to Savannah and pulling the head off, cleaned everything up, and installed a new head and gasket.
While driving home today it went about 120miles and it started the same thing again. Called AAA to tow me from I-26 and I-77 to Waxhaw. So, after money spent on a head and all the stuff to change it, and 2 hotel nights. I still have the same issue.
I replaced the radiator about 3 years ago, the water pump is new.
Any thoughts on what is going on?
Is the electric fan working when it's supposed to?
