A andyr354 NAXJA Forum User Location North Central KS May 17, 2004 #1 Is there a write up to cleaning it? I searched and no luck. My idle is low and jump around all over the place. 89 4.0
Z ZmOz NAXJA Forum User May 17, 2004 #2 It's not hard. Just disconnect everything attached to the TB and unbolt it. Remove all the sensors and spray the hell out of it with carb cleaner.
A andyr354 NAXJA Forum User Location North Central KS May 17, 2004 #3 If you remove some of those sensors don't they need adjusted on reinstallation?
R RINGKONG NAXJA Forum User Location Nebraska May 17, 2004 #4 andyr354 said: If you remove some of those sensors don't they need adjusted on reinstallation? Click to expand... yes.. have a look at the seafoam post.. its a few posts down from here.
Z ZmOz NAXJA Forum User May 17, 2004 #5 andyr354 said: If you remove some of those sensors don't they need adjusted on reinstallation? Click to expand... Only the TPS on an 87-90. You could probably get away with leaving that on there if you try not to spray it directly with carb cleaner...
8 89xj NAXJA Forum User Location aston,pa May 17, 2004 #6 RINGKONG said: yes.. have a look at the seafoam post.. its a few posts down from here. Click to expand... i say no. no adjustment needed as long as you dont take of the tps. iac can be removed. disconnect the iac and tps. you can leave the tps in, just dont spray cleaner all over it. the iac should be cleaned real well with cleaner. i clean mine once a year on my 89 and no need to make an adjustment(although i know how).
