XJensen
- Sacramento
RE4.5 lift with three pucks bolted. easier to get the coils off if you unbolt the pucks
It takes me 5 or 10 mins to take my coil out of eitherside of my jeep in a gravel driveway, coilspring compressor tool a jack and a few other sockets and what not and bam!
Depends on the amount of lift.
1 puck for every 1.5" of lift or so.
So for 4.5" lift, use 3 pucks.... u get it.
Black tape the pucks together heavily.
Put them in the vise, drill a center hole.
Choose your bolt size/ length you need & nut.
Remove the coil spring, in the center of the coil bucket drill a hole.
Recess a nut into the hole, make sure it's square & flat. Tack weld the nut into place not damaging the threads. If the nut sticks up some, grind it flush with a flap wheel.
Put the puck stack inside the coil.
Install the coil. Trap the coil.
Now thread the bolt into the "nutsert" and tighten the puck stack down.
Done.
Let the suspension droop, coil comes out.
Lift hieght has nothing to do with bumpstopping, shock lenth and amount of fender trimming does.
i would have counterbored the top puck so that the bolt head was reccessed. it's going to tear up the bump stop in no tome.
it has everything to do with shock length (expanded/collapsed), shock mounting, the % of droop desired, and tire clearance. people who base it on how much lift they have simply do not have the knowledge to figure it out correctly based on their setup.What??????????
Why the hell do you need longer shocks?
Because of the amount of lift!
That's the most illogical post I've ever seen.
1. The amount of lift increases the distance between the factory bump stops.
2. Therefore you must DECREASE that distance so the bump stops make contact. (PUCKS)
3. More lift = more uptravel.... BUMPSTOPS STOP UPTRAVEL. Limiting straps stop downtravel.
4. More lift = longer/more bumpstopping.
4. It has ABSOLUTELY nothing to do with shocks whatsoever. Don't post false info.
I'd recommend adjustable bumpstop plates from DPG
In Soviet Slovakia, bump stop is made from baseball.Those are extended plates, I think just few more pucks will do it. I know it's ghetto but my wife is going to kill me if I keeping dumping money into this thing.
Pinch seem in front has been flattened, but I will see if I can make some more room in the back. Those are the RC Fixed LCAs, so yes some adjustables will help me and prob be the next move. Thanks for all the suggestions.
What??????????
You are a tard..
Lift height has nothing to do with suspension travel. I only have 4" of height, but I have 11.5" of travel. 6" up and 5.5" down.
Those numbers only exist because of the length of shock I run. Really, I could have 4 more inches of uptravel before my axle eats the oil pan.
However, that 4" isn't available to me due to the tire/inner fender issue and the shock being mounted too low.
Once I get around to it, I will open up the inner and outer fenders, run a hoop for a longer shock, and get that uptravel back.
Lift height ( or ride height) only matters to the amount of bumpstop you run based on tire size and shock length. If I had the same length shocks and the same size tire but 2 more inches of lift, my bumpstops wouldn't change.
I heat the head of the bolt, when tightened down it counter-bores itself.
