- Billings MT/Rapid City SD
Started as a rocker replacement. Planned on following Starboard's project.
Jeep started as this, the rockers were peeling out of the body where they were welded and really bent.
Turns out the 2x4 tube that I was told was installed was just angle iron welded to the body. Wonderful, I guess it last for 5 years.
So I started cutting, cutting and fitting of the 2x6 tube.
moved the door hinge up
testing the new rocker in
Fit pretty well, bummer that the sheetmetal is bent but I'm not spending time to straighten it.
Cut and capped the ends.
Driver side tacked in
Passenger side before and after. Driver side took a couple days but the passenger side was done in a Saturday afternoon.
