Today on How They Do It: Plumbuses
Everyone has a plumbus in their home. First you get a 99 XJ with a NP231, HPD30, and a D35.
Then you add:
New headlight harnesses, IPF housings, 90/100w bulbs
30x9.50 General Grabber AT2
Hella Aux lamps
Head unit and 10" sub in a sealed box
Bilstein 4600
And drive it all over the country for a few years until the suspension and driveline bearings are screaming for mercy.
I need new pinion bearings and seals. My springs are sagging and hitting a bump at most speeds slams the bumpstops. It would be wise to replace the springs and rebuild the diffs
But I came home from the junkyard with an 8.25 and a front driveshaft for $250
Both axles will get a full rebuild and 4.56 r&p. Disc brakes for the 8.25 :yelclap:
Then you add:
Hella Aux lamps
Bilstein 4600
