Muddy Beast
- WA
Man I wana see more pics of that engine bay...looks like you've done quite a bit of mods!
~Scott
~Scott
~Scott
this oba project is a big confusing mess....the compressor fitting for the outlet side I cant find a fitting to work for. I wish home depot was next door so I dont waste a couple tanks of gas just trying to figure stuff out.
i just used the factory lines. i cut mine at the metal part of the line and hose clamped it. my take on this is that if you are running a pop off valve near by it will only build pressure to that point. so the risk of the hose clamp blowing off is not that big of a deal. mine works fine. :dunno:
there are pics in that other thread if you need em.
http://www.naxja.org/forum/showthread.php?t=990679
Are u sure you have the inlet/ outlet right? When I first did mine i had them wrong and it acted like it wasn't building any air pressure. Check where u have your inlet coming from and see if you have air comming out of itwell got it all done tonight and then filled the oiler and fired up the rig. then I touched the power to the battery on the compressor. Clutch engaged but not no pressure built up and I dont believe compressor is even working. Guess i should have checked if it was seized before I started this stupid project.
