- Dracut, MA
Alright, so I figured because I'm bored at work, might as well get going on a build thread...by the way, please keep in mind that this is in fact my first build thread...I'm usually terrible at remembering to use a
hoto:
I've got a 95 4 door, bought bone stock in August of 06. Rust free, from California... a rare treasure in New England.
The day she came home...
Went through a couple quick phases the following summer, 31s open/open, 33s open/locked and Clayton, then gears, rear 44, locked 30...
To cut a long story short... It's gone through a bunch of phases in the past couple years, most recent being 6.5" coils, RE leafs, 4.88s open/locked, and 37" creepies.
So, this thread will be to follow along my next stage in the build... front EB44, using my Clayton lowers and building a 3 link, chop, and cage.
Planning for the chop to look something like this, using the rear section of an MJ cab to close it in. ....save the MSpaint comments please.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So far, for the 44 I have taken all the brackets off, and acquired the following...
Mile Marker hubs
full spool (most likely will be going with a lunchbox instead...)
broncograveyard heavy duty shafts/760 u-joints
broncograveyard disc brake conversion
hi-steer arms from jeepxtremes.com
flat top knuckle (DS)
The 44 to-buy list...
passanger side flattop
gears/install kit
ballistic fab coil/LCA/shock brackets
ballistic fab OTA trackbar bracket
ballistic fab DIY crossover steering with TREs
For the chop I plan to graft in an MJ cab section that I will be picking up tomorrow afternoon, and then starting on the cage. The cage will be constructed of 1.75" .120 wall DOM, and from my guesstimations so far, I'm looking at between 140-180 feet of tubing. I'll use Ruffstuff's unibody stiffeners... the unirails could use some help anyway. quick cellphone pic for proof of that:laugh3:
And finally, for the 3 link, I'd like to build a mount off the Clayton crossmember on the passanger side, so that I can avoid the need to build a truss over the diff. Plus, I haven't been the biggest fan of the radius arm design's tendency to unload etc... it just doesn't feel stable. Hopefully doing this will help that out...
After everything's back together, I'll be looking into tires... as of right now, I'm considering 36x13.50 bias IROKs, 35x12.50 creepy crawlers, 36x12.50 SXs, and possibly 37x12.50 creepies. Any suggestions here are more than welcome![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Because I'm at work, this is all I can access at the current time for pictures and whatnot... When I have a few extra minutes I'll be sure to snap/upload more of the parts I have collected, and more as they come in.
Any and all constructive criticism is more than welcome, I wanted to start this thread before I really get going in order to assure plenty of time for people to offer up their ideas/thoughts on everything...Hope you all enjoy the build
![firstday.jpg](/proxy.php?image=http%3A%2F%2Fi38.photobucket.com%2Falbums%2Fe115%2Fihittreesalot%2Ffirstday.jpg&hash=7936762d0ed0a1193c7e244d48fe453b)
![GetAttachmentaspx1.jpg](/proxy.php?image=http%3A%2F%2Fi38.photobucket.com%2Falbums%2Fe115%2Fihittreesalot%2FGetAttachmentaspx1.jpg&hash=30603d5c837712831a6f8f8919af28b3)
![chop.jpg](/proxy.php?image=http%3A%2F%2Fi38.photobucket.com%2Falbums%2Fe115%2Fihittreesalot%2Fchop.jpg&hash=5f9072825e7dfc7b3046572a9373f03c)
Mile Marker hubs
gears/install kit
![0209091245.jpg](/proxy.php?image=http%3A%2F%2Fi38.photobucket.com%2Falbums%2Fe115%2Fihittreesalot%2F0209091245.jpg&hash=77ab19c0773d527cb36dc2b44c5311db)
