THRASHER
- Santa Cruz, CA
whats up, I have been lurking around since august when I bought an 85xj for a trail rig buildup. I am just finishing p the front leaf conversion, should be finished by next week. Here is my setup...
-I went with a 31 spline 9in in the rear. I hadnt planned on running this axle, but I traded my dana30 and my 35 housing for it. I left it full width.
-Front axle is a 30spline 44 out of a cherokee chief. Its not a disco and has u-joints and not cv's. It is the same width as the 9in, I just need to figure out what to do about the bolt pattern. Does anyone know of a good set of wheel adapters that arent to wide? The knuckles are flat top, so I will be using a highsteer arm on the passenger side for now just to raise the draglink until I get the funds for a new tierod and another arm.
-My front crossmember is 4x4x1/4 in angle (thanks for the idea Brett). I used Slickrock shackle hangers and shortie shackles. For the rear hanger I am using the lower control arm mount. I have the springs hung and center pin to center pin is 30.5in.
The rear axle is in, I just need to get some shims or rotate the perches a few degrees. I also need to pick up a dakota brake line. I have the perches for the front, I just need to weld them on and then I can bolt in the axle. I am using stock waggy springs, I might switch to yj's depending on the stance. I have some 37x12.5x15in SSR that I will be running. I will try to get some pics up soon. The axle should be hung by tuesday and my goal is to have it on the road by next week...
