The Crawl is coming up quick!
What is it doing?
well at first i had fuel rail issues so i got it swapped out today... no more leaky leaky.... the battery was shot from cold winching it up on the trailer so its on the charger till tomorrow.
when i had it turning over before it was popping like it wanted to fire but wouldnt, i figured it because it was shooting fuel out the front of the rail at a ridiculous rate.... im pretty sure i have the dizzy indexed right, oil pump key turned to 11 oclock and it lined up perfect with 1 at TDC.
hopefully with the fresh battery it will fire right up tomorrow... everything is hooked up and ready to go
at this point i dont care if it makes as much power as a freakin 22re.... i just want it to run
I am going to be filling out the registration form for the crawl tonite.... im pumped about it. Hopefully the ole jeep can make it up there and back... haha, guess thats half of the adventure!
If you don't get it going, feel free to bring it down. I'll get it going for you. Im being serious here. I would come up there and give you a hand, but I just don't have time. I bet the timing is wrong... simply b/c it seems like I run into this quite a bit.
i need to get busy and order that darn lift
Mark
might take you up on that monday and tuesday if i cant get it purring by then.... i need to weld up the trailer ramps anyway and i may add some tie down hooks to the trailer
and fix your trailer lights... so i dont ram in the back of you at unexpected stops
mark
