Thatxjguy's 1999 Jeep Cherokee Build 'Hole in the Pocket'
How's the air flow with those vent switch pods? Been eyeing them for a while but can't deal with losing air flow during the summer.
No need to worry about airflow because you've got two good vents on either side of you, and a bunch of air flowing straight back :).
Unfortunately, you just can't adjust the direction anymore.
UPS came today and dropped off some goodies.
Stainless steel braided extended front brake lines, and rear shock bushings:
Those shock bushings are going to come in handy for my free rear bar pin eliminators that I'm making out of the brackets from my rear sway bar that I removed:
Today I got some more goodies.
My LED rock light kits came today:
And so did my 4-AWG wiring kit from 5-90 for my 136-amp alternator:
And I just finished installing them tonight:
For those that don't know Jon Kelley (5-90) he's an amazing guy with great electrical knowledge. I talked to him about all of my concerns and he answered all of my questions thoroughly..
The quality of his cables is top-notch and better than what you'll find at the store. I highly recommend his wiring kits if you ever do a Dodge Durango alternator like I did.
Converted driver seat from power to manual today:
Also, installed the Hooligan 50-inch light bar brackets to replace the Inspired Engineering ones. They sit lower for a lower-profile on the Jeep. I also removed teh roof rack:
Yeah, it's a huge pain the ass. The big thing is that you need to have a lot of time. I split this up between two days – although labor-wise, we spent 6 hours total actually doing it.
The most annoying part was probably the steering column. There are so many plugs there, and I had to be careful not to spin the wheel to prevent damage to the clock spring.
I know this is from forever ago, just wanted to chime in on the HVAC box for anyone that is reading. After doing about 5 of these on different jeeps and twice on my own (bad day) I found its much easier to leave the steering colum in and just remove the steering wheel. This and for the most part, you can leave a lot of the plastic on the dash as well.
You're jeep looks sweet. I love that gun metal color :thumbup:
Removed the crappy Rough Country anti-sway bar quick disconnects and installed some beefy new JKS anti-sway bar quicker disconnects today:
Lots of redundant money spending going on with this jeep. Give it a while and all them light bars hours spent on switch panels and replacing parts with parts with parts will seem funny.
Clean jeep though looks like a solid daily driver that anybody would love. But in time the bug will bite and the grinders will come flying.
Yup, when I got the Jeep I was on a high school graduate budget. I couldn't afford quality. I ended up with Rough Country crap.
Now I have a job and I can start making some stuff happen.
I am now planning BDS 4-link long arms & Clayton springs.
But no I'm not going to buzz-saw anything. I'd buy a beater before I started trimming things on this.
A complete coolant power flush seems to have fixed my temperature woes permanently. I finally have alien blood instead of mud:
Also, a new Moog tie rod end for the pitman arm and drag link to fix some slop in my steering:
And to top everything off, a set of four Cadillac horns to replace the dinky factory horns:
Did a good ol' coolant flush:
Replaced a tie rod at the pitman arm to tighten up the steering:
New leaf springs:
I also removed the shackle relocation kit temporarily until I find a decent sized shackle that won't add 1.5 inches of lift in the rear and will still clear the brackets.
These fixed a problem where the bushing was sliding out of one of the eyes:
New valve cover gasket went in:
New valve cover grommets and valves:
And also just did new front axle U joints. I went with Spicer 760X joints:
New Timken hub bearings are in on both sides:
New flex joint bushings on all the control arms:
And to top it all off, new axle upper control arm bushings:
