temp. gauge probe mounting
mike harris
ohio
I have some mini triple gauges mounted in the jeep.I have the temp sender probe mounted inline one of the radiater hoses that go into the heater core.The problem is the coolant there does'nt give an accurate reading because it's somewhat cooler than that in the block.Where do you guys mount the temp probe?In the block would be the obvious choice....but where?
