Taction Bar angle
hadfield4wd
Roanoke, VA
OK, So I'm making a traction bar for the new rear that will be going in. I know that without you want the pinion set at about 2 degrees below straight because when you hit the gas the torque will bring it in line. Is this the same figuring there will be some play in the bushings of the traction bar or do I point it right at it?
Matt
