jeeptec
- atascadero california
Synergy suspension coil springs. Per Synergy online catalog
5.0 TJ Wrangler
4.5 JK Wrangler
3.0 plus XJ. ( I had 3 3/4 on my XJ)
Good riding spring with good flex. I did a long arm and went up in lift. $50.00 obo
Rusty's heavy duty crossmember. Drops transfer case 1 inch and keeps ground clearance. This replaces those 1 inch spacers that get put in between the stock crossmember and frame when you lift the vehicle. Also is a heavy duty steel crossmember not that stamped sheet metal one that is stock and bends the first time you crawl over a rock. I went long arm and mine got replaced . 75.00
I'm in Atascadero 2 hours above Santa Barbara.
I can also get a parts train going. Also I have guys I work with that go to Ontario for training so they can bring them down.
5.0 TJ Wrangler
4.5 JK Wrangler
