SYE-DS-SHIMS Question
Purple
yes, even with sye and cv driveshaft you need shims, go to tom wood's site, and read driveline 101... that will give you an idea what needs to be done, i have similar setup, and i have 3* shims
I got right at 5" with a RE lift, swapped out my Dana 35 for a Dana 44 and wound up with 4* for the shims. I think that my driveshaft measured 34", but that might be wrong. And I do not have my t-case lowered.
Just my 2 cents worth,
Robert
w/ the cv shaft you want your pinion directly inline with your driveshaft or a hair lower to compensate for axlewrap. That is why u need shims...
