Euology101
- NYC
Installed the SYE (Advanced Adapters on a NP231J) last weekend. I know I need axle shims under the leafs.
Just want to make sure I have this measure thing down correct. Yes, I've read, and seen how other people do it, but it seems like everyone has their own way of doing it, so I'm just double checking myself to see if anyone catches a flaw in what I've done.
1st measurement - Angle of Drive Shaft. ~17-18*
2nd measurement - Flat portion on the side of the tail housing on C8.25 diff. - 8-9* (This spot appears to be parallel with the yoke, so I figured it would be easy to measure there)
3rd measurement (more to check myself?) - face of yoke on C8.25 - (drive shaft was already installed, so I just aligned it with the face based on eye ball) This appears to be about 92-93*. From what I've read - subtract 90 degrees to get the degree of the output on the Diff. 2-3*? - This doesn't seem right, I'm sort of throwing this number out.
If I assume 1 and 2 are done correctly, I'm about 8-9* out, and if you subtract 2* because you want to be under 2* when not under load, I should need a 6* shim. - Any other measurements seems like I need a MUCH larger shim, which does not seem to be typical with the lift that I have. (most people say 1* per 1" of lift "typical".....is anything ever really typical on an XJ?)
OME 3.5" lift springs in the back, I did not install them, so I'm not sure if this is netting more than 3.5" because I don't know what the original height was. I've read it was 17" from center of axle to start of fender, and I'm more like 21" so I'd say its safe to assume I have about a 4" lift.
Drive shaft by Titocci, on Flickr
1st Measurement
Diff - Output by Titocci, on Flickr
2nd Measurement
Yoke Flange by Titocci, on Flickr
3rd Measurement
1st Measurement
2nd Measurement
3rd Measurement
