sarvermr
- Little Rock, AR
swap finished: fullwidth d44 and 9", 38" swampers, radius arms, traction bar, etc.
i've received quite a few PM's with questions so i took a few more pictures and started a thread with a title that actually tells what the thread is about.
here is my rig:
and an action shot from its virgin run in hot springs:
i swapped in a 1977 ford f150 high pinion D44. i cut off the radius mounts and turned them to get better caster angle. i also made all mew brackets to get everything to jive right.
new spring mounts so the springs would not bow:
track bar bracket to get everything parallel and not bind:
I reused the stock radius arms but sleeved the stud with tube and added a threaded insert and a heim joint
here is my rig:
