Superwinch EPi9.0
12 Volt Man
NAXJA Member # 1383
South Weber, UT
Financial issues force me to sell this. This winch has been on my rig for a year. It has NEVER been used.
$550.00
Killer deal when you factor in the synthetic line.
Standard Features:
Powers Load IN and OUT
Automatic Load Holding Brake
Quiet, Efficient, Full Metal 3-Stage Planetary Gear Box
Freespooling Clutch for Fast Wire Rope Payout
Efficient 4.6 hp Series Wound Motor
Heavy Duty Sealed Contactor
Durable Handheld Remote Switch on 15' Lead
Heavy Duty Roller Fairlead -- Roller fairlead does not attach directly to the winch.
21/64" x 125' wire rope
Extremely low amp draw (260 amps at 8,000lbs vs WARN XD9000i 415 amps at 8,000lbs!)
External Brake (no drum heating issues w/ synthetic rope)
Specifications:
Rated Line Pull (Single Line) - 9,000 lb. (4,082 kg)
Motor - 4.6 hp, series wound
Gearing - 3 Stage Planetary
Gear Ratio - 156:1
Freespooling Clutch - Lift and turn
Braking - Automatic 100% Load Holding
Wire Rope - 21/64" x 125' (8.3mm x 38.1m)
Dimensions - 23.35" l. x 6.26" d. x 7.13" h.
Drum Diameter - 2.5" (64mm)
Drum Length - 9" (229mm)
Weight - 114 lb. (51.8 kg)
Switching Method - 15' Rubber Handheld Remote
Switching Mechanism - Heavy Duty Sealed Contactor
Roller Fairlead - Standard
Pulley Block - Standard
Color-Coded Wiring - Standard
Call Rob:
725-5045
located in South Weber
How much are you asking for it??:shhh:
I saw your mighty red heep in front of Gateway one day while I was out riding my bike. Unfortunately the same circumstances that are forcing you to sell are also forcing me NOT to buy. :(
