- Denver, CO
Here is my list of crap, the 1500$ added on is for misc crap that I either dont have, or want to get to make it faster, could include a junkyard 29 spline 8.25 w/gears and welded, ignition stuff, maybe even a borla...
I am picking up this 87 XJ next week, for 300$, I had originally planned on fixing it up to sell to my sister, or to someone else to make a buck this summer, but I think this would be more fun.
So I got bored, and was watching horsepower TV (never a good idea
) and then looked at Dino's site, and devised this list...I have some parts, like the 258 crank/rods. I have a yard with a few HO's, that charges 150$ for a complete long block...so I think this estimate is fairly close...
What do you guys think? What am I missing? Teh Jeep im getting will only be minus the block/head, so thats no problamo.
Another thought will be buying/trading out the 4wd tranny, tcase, and front end for a lighter 2wd setup...that should gain me some 1/4 time.
Specs at a glance will be: 87 XJ w/91+ block/head, Stroked to 4.0 crane cam, 2wd AW4 tranny, 8.25 rear w/4.10s, 75 Shot of NOS.
I have no idea how fast it will be...Dino maybe you know? Should be pretty quick...And if any of this doesnt make sense, maybe I can help decifer my ramblings.
ORIGINAL COSTS:
Junk Yard 4.0, Mostly Complete Long Block: 150$
Jeep: 300$________
450$
FREE LIST
258 Crankshaft/Rods: FREE
Crankshaft pilot bearing #53009180AB: reused
Main bearing studs: stock '00 reused
Crankshaft sprocket #53020443 & timing chain #53020444: reused
Main bearing girdle & retaining nuts: reused
Cam bolt kit: stock free with block
Crank pulley spacer: free
Oil pan: stock '92 free with block
Oil pump: stock '00 reused
PARTS FROM AUTOZONE:
Federal Mogul main bearings #FM7211M.030: 35USD
Crankshaft rear main seal #05018594AA: 7USD
ARP rod bolts (AMC 258) #112-6001: 35USD
Sealed Power 677P +0.020 pistons: 90USD
Hastings +0.020 piston rings: 30USD
Clevite 77 camshaft bearings #SH-549S: 17USD
Crane camshaft CRN-753905 & lifters CRN-99278-12: 179USD
Main bearing girdle spacer kit (14 hardened 5/16" steel washers): 1USD
Camshaft sprocket #53020445: stock '94-'98 27USD
Crank harmonic damper #33002920T: 29USD
Pioneer brass freeze plugs x7: 7USD
Victor Reinz lower gasket set #CS-5713X: 29USD
TOTAL: 486$
LESS 20% Discount: (97$)
TOTAL: 389$
PARTS FOR HEAD:
Head: FREE (already included)
Standard Abrasives Deluxe porting kit 40
Valves lapped and polished: FREE
Head surface milled: FREE
Valve seats reground & polished: FREE
Head hot tanked: FREE
Mopar head gasket: 19
Combination manifold gasket: 15
Intake & exhaust valve stem oil seals, t'stat housing gasket: 14
Cylinder head freeze plug: 4
TOTAL HEAD COST: 92$
LESS 20%: (18$)
TOTAL HEAD COST: 74$
Mopar Performance valve springs #5249464, retainers #4452032, & locks #4529218: 153USD (Minus 20% = 140$)
Victor Reinz upper gasket set #HS-5713Z: 45USD
STROKER HEAD WORK: 185$
MACHINE WORK: FREE
65 Mustang TB: ???
00 Intake Manifold: ???
TB Spacer: Have one
NOS: 500$
2.5” Exhaust w/Cutout: Have it
MISC STUFF (plugs, wires, air filter, etc): ???
ESTIMATED REST OF COSTS: 1500$
TOTAL COST: 2598$
ORIGINAL COSTS:
Jeep: 300$________
450$
FREE LIST
TOTAL: 486$
TOTAL: 389$
PARTS FOR HEAD:
LESS 20%: (18$)
MACHINE WORK: FREE
65 Mustang TB: ???
TB Spacer: Have one
NOS: 500$
TOTAL COST: 2598$
