- Kansas
I will say if you dothis. I found it real easy to attach a small 18 gauge wire to the bolt, fish the wire through the hole and pull the bolt into place! I tried using long needle nose and fought with those awhile before i did the wire trick!
Having fingers would have probably made it a little easier also!
Adapt and overcome!
Birth! Left hand is also jacked. But at least i have a full thumb and index finger on that side! I just couldn't take a picture holding the phone with my right hand! :roflmao:
I dont let it stop me! Im a full time EMT / Firefigher and can stick a needle in a vein from across the room, im also the Rope rescue Guru for our Tech Rescue team and tie knots around most people. They always try harder when someone says "the Fingerless guy can do it? whats your excuse!"
Pretty sure my parents were sadistic my first toys were Lego's!
