XJJack
- Hawthorne, CA
I was wondering if anyone has treid to stoke there (fresh) 4.0 byt taking off the pan and timing cover installing 4.2 crank and rods on the stock pistons and slaping it together? I seams like the parts should work (not sure about the cam) and I know that it will be tricky geting the piston rings back in from the bottom but it can be done.
So what do you think is this a posable option?
