srmitchell
- Mckinleyville (Humboldt) CA
4.10s are a just a tad high for 33 inch tires. 4.56s are a little low. 4.88s are way too low for 33s unless the vehicle is for offroad only. highway driving all you will do is wind up your rpms. i would do the gears over the stroker. i had a friend put 4.56s in his jeep on 33s... rpms ran a little high. i would run 4.10s if i were you. if you plan on going bigger then put the 4.56s in it.
My xj has the aw4, 4.56's, and 32's. 2500rpm @65 mph.
It's slightly over geared and awesome. 4th gear/od kicks in at 35 mph, and will take me all the way past legal highway speeds.
It's the most fun at 75 mph, cause 3,100 rpm is a sweet spot for torque.
