mhead
- Encinitas, CA
Re: Stoker: Titan Engine: My Story
Electrode on rotor looks to be maybe 15 distributer degrees or 30 crank degrees. Using crank degrees the rotor leading edge would be at #1 tower something like 30 degrees advanced and the trailing edge would arrive at #1 tower at just a degree or two advance. I guess it kinda makes sense since engines are run with spark advances of maybe 10 degrees. I bet some careful measurements would make it all plain.
But what really got me is that when attempting to start the engine I did see spark at #1 plug. Seems like any spark would make the engine pop or backfire or something. But it did nothing. Thats what got me. If it had backfired or run really crummy I would have understood. Oh well.. It runs now but I'm going to put in the next reply seperate as you'll understand shortly.
xj2win said:The same thing happened when I was installing my distributor and I had a hard time coming up with an explanation. The only thing I could think of is that the electrode is on the trailing edge of the plug at TDC because it is just ending the spark sequence. By the time the piston is at TDC the fuel should already have been ignited, so the spark has to occur ever so slightly before the piston hits TDC. Also take into account the spark has to go from the electrode through the wire and plug. There's minimal resistance, but it does take a very small amount of time.
