030400 - INTERMITTENT BUMP FELT AFTER VEHICLE HAS COME TO A FULL STOP
Date: 06/23/00 (supercedes 030799 dated 10/29/99)
Model year(s): 1999-2000
Description: A condition may exist where the vehicles owner may feel an intermittent bump (stop-bump) once the vehicle is brought to a full stop. The repair technician may erroneously diagnose this condition as a delayed transmission down shift into first gear. This condition may occur 3 to 20 seconds following the stop or when the load on the rear driveline is reduced (e.g., when the applied brake pressure is decreased). The stop-bump condition may be the result of a binding between the splined surfaces of the rear propeller shaft slip yoke and the rear output shaft of either the transfer case or the transmission. As load on the driveline is reduced, the bound slip yoke will release suddenly causing a bump-like sensation. The condition may be intermittent. If the above condition has been experienced, then perform the Repair Procedure. The splined surfaces on the slip yoke section of the new propeller shaft are nickel coated to reduce the opportunity of binding.
Details: THIS BULLETIN APPLIES TO VEHICLES BUILT BEFORE SEPTEMBER 20,1999. A WJ EQUIPPED WITH A 4.0L ENGINE, A NV242 TRANSFER CASE, AND A 198 RBI (M35) REAR AXLE USES A DIFFERENT STYLE REAR PROPELLER SHAFT THAN THOSE WHICH ARE ADDRESSED IN THIS TECHNICAL SERVICE BULLETIN. FOR THIS VEHICLE, THE SPLINED SURFACES ON THE PROPELLER SHAFT SLIP YOKE AND THE TRANSFER CASE OUTPUT SHAFT ARE GREASED TO PREVENT A BINDING CONDITION AND DO NOT REQUIRE REPLACEMENT.
