bobinyelm
- Waxahachie, TX
Recently picked up a very clean '01 XJ (94k miles-zero off road use) and compared to my '96 XJ, the steering feels "stiff." Not "hard" like w/ manual steering (though it does take more effort to steer), but it doesn't have a "live" feel like even manual boxes have, rather with what I would describe as friction. The steering is "stiff" and "dead."
It's as if something is adjusted too tight in the steering box, but unlike when you DO overadjust the box too tight, the friction stays the same regardless of steering angle (it's not just stiff at center where the worm is ground tighter).
I understand the DC changed the box at some point to MAKE the steering stiffer to make the XJ feel "heavier," but:
1) I cannot confirm this
2) If it's true, I don't know what year they did this
I DO know that many reviews by the press mentioned "stiff steering" and poor return-to-center (due more to stiffness than lack of caster) on the newer XJs.
Yes, and I did grease all the fittings, and though I have not disconnected the steering linkages to see if something is binding, I suspect it's "in the box."
Anyone know when they changed the steering feel, and how far back I'd have to go to buy a rebuilt box to swap into my '01?
Last question-without getting deep into it, the steering box is rather buried in the XJ. How long to change one?
Thanks,
Bob
Thanks,
Bob
