steering linkage upgrade
No more pic requests, do a search for steering in modified tech and you will probably come up with more answers than flames. If you don't know what I'm talking about go to search in the top right, click advanced search, select modified tech and in the box on the top left type in steering...good luck.
QA1 ends, 1.5" .250 DOM. 8" of lift trac bar is 1.25" .250 DOM, JKS bracket
ert01 said:
Why's your diff cover welded on?
It's a Ford 9" axle (has a 3rd member)
OTK steering is 1.25", 5/16" wall DOM with QA1 Chromo rod ends direct tapped into tube, hi misalingment spacers, and saftey washers. Need a FSJ pitman arm now though.
TB is 1.25", 1/4" wall DOM with QA1 Chromo rod ends direct tapped, custom mounts on axle and frame ends.
