MaxxXJ
- Bakersfield CA
Bottom tie rod is fine they do pivot a little, everyone does alignments differently, apparently I'm the only one who runs a string from the hitch around the back tire and across the 2 points on the front tire. If it touches the front of the tire first it's tow'd out, if it hits the back first with a gap in front It's tow'd out OR the wheels aren't straight, I'd go to the other side and see how that side looks. If all visually looks within an 1/8 off ill run it I haven't pulled a tape measure unless I second guess myself.
As for steering wheel slop there should be none, you have something bad in your steering system. My last problem was the steering gearbox. Now it has next to no slop at all.
As for your poplin noise I would do your visual inspection, if all looks safe, for me it sounds like a bolt is shifting ever so slightly and popping, think about it, it's the same "pop" you hear when you first break loose a stubborn bolt, because it transfers to the body, I can bet it's a control arm bolt... Otherwise you'll find out what that noise is when it breaks
