Please contact us directly if you have a problem with our product. We can only offer customer services if you opt to use it. [email protected] or 269-353-1184.
You know, after reading so many good things about JCR, I'm kinda disapointed with this product. First of all that same hole did not line up and I had to cut off that part to install it. Then the 3 remaining holes lined up well but they are not welded all the way around, just at 3 and 9 o' clock. I also had to remove the sharp edges from the drilled-out holes with a file.
JCR products are great but obviousley if they're not painted they're not prepped and need deburring ect, I see this as no real issue and I'd rather be the one to coat my stuff because powdercoat does NOT hold up to weather in the northeast!
