Bones
- Mid Missouri
Well I need steering advice. I have been through two power steering boxes in the last year. What is even worse is that I have had the XJ parked for the last 6 Months. They fail at the output shaft. I run really sh*tty caster angles so even a little bit of play causes bad road manners. I want to fix this thing before Moab in Oct.
I need to come up with a stronger PSbox. I have heard rumors of using J20 boxes. Can this be done? What other options are there? Is it worth just having a stock box cut to replace the bushing with a bearing?
Thanks
Bones :skull1:
#6
Thanks
Bones :skull1:
