- Nashville, TN
I got a box from a 1997 ZJ Tsi model. The output (pitman shaft) seal needs to be replaced.
I got the old seal out. The snap ring was just floating around the shaft splines.
In this photo, you can see a groove about 3/4 way down. I assume that I need to put the seals all the way in, then put the snap ring into that groove?
That seems to be the only logical answer, but thought I'd ask before just shoving the seals in there.
