Steering bolt holes enlarged, plate it?
CarbonXJ
columbia
So I'm in the process of changing the steering gear (again) and my bolt holes are enlarged! I torqued to spec, 70ft-lbs, but looks like the washers pulled inside the frame rail - thanks JCR for the washers (not) I had a 3/16 plate made to match my JCR spacer for the box. Think this is enough to make it nice and sturdy? I notched the plate to clear my fender brace and sealed it with primer/Hammerite.
Sent from my LG G4 using TapaTalk
Might be a good time to think of sleeving the bolts but that plate looks like it will disperse the load pretty well too. Maybe tack it to the frame in a couple places too, so it doesn't shift.
The steering box bolt holes are oversized to begin with. I recently took advantage of that feature in order to position my steering gear box such that it would better align with the sector shaft support bearing on my Boostwerks mount.
The washers that came with my JCR steering spacer/brace kit were also junk. I noticed that the first time I tried tightening things down a year and a half ago. I recommend finding a source for proper, hardened washers.
I've got hardened washers now to match the new bolts. I should have noticed the old ones pulling in when I was installing the first time. It was dark and I just had a shop light.
I'm not sure if I need a full brace kit, nor if it will work with my bull bar. My local welders are either iffy, or costly as well. This rig has only seen the interstate for the last few months sadly.
Here's the real solution, with weld-in sleeves which will stop your unirail from flexing.
http://jksmfg.com/i-8938560-cheroke...tem-driver-side-only.html?ref=category:381107
Installing this keeps the steering box bolts tight and prevents cracking. 10yr/100mile tested on my rig and I've got no cracking and never had a bolt come loose on me. I did both sides, just because.
http://jksmfg.com/i-8938561-cheroke...teering-brace-system.html?ref=category:381107
Those are a must! Keeps you from squishing the "frame" and sucking the bolts through. If you don't have them, the "frame" can squish down a bit and allow the box to be loose... and bad things happen with a loose box!
Would the plate I have and sleeves for the bolts keep the holes from enlarging or pulling through?
I too did both sides on my 92 about 8-10 years ago.. can't remember anymore. Not a single issue since installing the SBS. Gives you tow hook mounts as well. Nice kit. Crush sleeves are a must!!!
Stinkyfab makes a weld in repair/reinforcement that would fix your problem here.
http://www.stinkyfab.com/vehicle-sp...in-inner-frame-plate-steering-box-spacer.html
Cal,
This SFR kit solves the spacer issue and beefs up the steering box area. Lacking weld-in sleeves, it will not prevent the unirail from compressing when the bolts are tightened (and loosening up as the rail flexes).
The SFR Front Frame Reinforcement kit has sleeves,http://www.stinkyfab.com/jeep-xj-cherokee-front-frame-reinforcement-kit.html but not the large inner rail plate that you have pictured. Combining both will provide a total solution.
If I hadn't already solved these issues on my rig, I would contact SFR and request that they remove the small steering box plate from their FFR kit and add the larger Inner Plate kit.
