starting problem
drkstrurethane
arvada, colorado
the other day i went to start the jeep and when i turned the key nothing happened all the lights worked so i just thought it was the starter i replaced the starter this morning and it started fine went to start it again to go to work and it did the same thing as before then turned the key once more and it started right up... it happened again at the gas station coming home from work and i was getting super pissed so i was just gonna push it and leave it then i tried one more time in neutral and it started so now i was thinking a wiring problem but i have no clue... any suggestions? thanks in advance
well i was experiencing the same problems and could not figure it out..... it seems like a dead batter but everything works..... it ended up being my transmission sensor.... all i have to do is push foward on the shifter, and then it starts right up..... that might help if not sorry
Neutral safety switch. The procedure to clean it has been written up numerous times.
Search on the full term or on NSS.
