Googenheimer
- Provo, UT
I have a 94 XJ 4.0 that won't start. Let me clarify that. It won't even crank over. I turn the key and nothing happens (as far as the starter is concerned). It won't start in park or neutral. The battery is fully charged and the positive lead that goes to the starter shows that 12.7 or so volts is reaching the starter. The solenoid seemed to be the problem because I used to get it to start by hitting it a few times. Now however, no amount of beating it will get it to work. Here's the interesting thing though. Whenever I take the starter to get it tested it works fine the first try and passes all the tests. I've had it tested twice now, same thing each time. I've cleaned the motor off, as well as the contacts, and taken the solenoid off and cleaned it. After I cleaned it and put it back together the solenoid would engage with a click, but the motor wouldn't turn.
I'm wondering if there is a wire or connection that could keep it from getting the right amount of juice. I've replaced one of the battery terminals so neither are corroded and both are tight. I replaced the starter relay with a new one and had no luck. Anybody had the same issue. I would replace the starter but I'm just afraid of spending the money for a new one and not having it be the problem. Especially when this one has tested ok twice. Any ideas?
