mtnranger
- conifer,co.
What kind of bolt is oem on the steering stabilizer tie rod end? I can't break it loose to change out stabilizer. It doesn't have much of a nut on the outside of the shock bolt where you can leave the bolt in the tie rod and just remove the nut on the shock side and slide the shock off? Anyone run into this problem. Put a whole lift on and can't get a simple shock off, go figure...
Also, where do you make adjust to straighten up the steering wheel? Its upside down now and 3/4 turn off. I tried the pitman arm trick but thats not it. Is it at the steering gear box?
