Squeaking in front end...Help!
darkfire07
NW Arkansas
I have an interesting squeaking sound coming from the front end of my '93 Sport. It only happens when I'm moving, so it must be driveline-related. A friend of mine thinks it's a U-joint....is this possible? What else commonly fails and makes noise like this? U Joints are ceap but I really don't want to do the breakdown ad rebuild to replace them only to find it's something else.
Thanks!
DF7
Does the frequency of the noise increase with speed? Could you classify it as "angry sparrows?" If so, it's likely the centering joint of the front driveshaft - that's the piec between the u-joints. Most driveline shops should be able to get you a spare.
It does get higher as I increase speed....then at around 45 it seems to disappear..but that may just be bacause there's enough other noise to block it out.....thanks man!
DF7
