sputter and hesitation durring accel.
rehab
The Citadel, SC
i just started driving my xj again and now it has some major issues. at about 1600-2000 rpm the engine coughs and sputters with the occasional backfire. it has the 4.2 block and 4.0 head and 24lb/hr. injectors. there is no cat and it has a slight exhaust leak that will not go away! i just put a new gasket on the manifold because i thought the intake was leaking but it still did the same thing. the engine has about 4000 miles on it. i bought it off a friend who rolled his rig so i put an 88 intake and all the sensors onto the engine that was in a 95. i checked the plugs and they were extremly white. so i built an adj. MAP sensor and it is running better buy the problem is still there. the map sensor now has about 7.2 volts running to it which is extremly high, since stock is about 5 volts. i checked the plugs and they are slightly black but when i turn the sensor down it just runs worse. i have been over every sensor, reading every manual and checked for vacuume leaks. i have asked everyone i know but i have came up with no solutions.
PLEASE HELP ME SAVE MY JEEP!
2 posibilities - Bad CPS or distributor indexing. See the distributor indexing saga on the street & Pefrormance forum - lots of good info. If you are SURE that the indexing is correct - replace the CPS
