Sorry in advance for the long post, I hate cooling systems.
So after finally getting my brake issues addressed, I finally got my '91 through inspection after sitting for a little over 3 years. I've been driving it every day for about 4 days with no issues, but I have noticed that the temp gauge creeps above 210 when sitting in traffic. This is happening in 90*+ temps. If I hit ~230*, the e-fan kicks on and the temps fall back down. This is how I remember it running when it was on the road previously.
Today though I was running some errands and came out of the grocery store to find a puddle of coolant under the driver's side. I popped the hood and it looks like coolant was spraying from the radiator cap. I'm guessing this is the case because the hood blanket was damp directly over top of it, as well as the front of the airbox and the area where the hood latches was wet with coolant. It's about 94* today, and I had the AC running before I stopped, but I never got above maybe 220.
I drove it home, let it cool, popped the cap (which was on so the warnings were upside down) and the coolant looks fine. The overflow jug coolant is a brownish color though as opposed to the green under the cap. The hose coming from the thermostat housing was hot so I'm assuming that it's working properly. I squeezed the hose from the thermostat and the level drops under the cap.
I fired it back up after putting the cap back on (so the warnings were no longer upside down) and let it idle for a good half hour. No issues, no spraying, nothing. I ran the AC, still no issue. There are bubbles coming up into the reservoir while it's running.
Could it be that the cap just wasn't sealed properly? I'm at a loss here and don't want to risk an overheat scenario. I am hearing a really loud, rapid dripping coming from somewhere in the motor right after I shut it off. I took a video but can't find anywhere to upload it.
Edit: I took some pictures of under my cap and what looks like a drip from under the filler neck.
Coolant:
Drip from under cap. I can't tell if this is dripping from taking the cap off, or if it's coming from the filler neck itself.
Thanks!
Coolant:
Thanks!
