Slonopotam
NAXJA Member #1358
- San Jose
Hi,
1. One of the retailers sent me a wrong u-joint, later they sent me the correct one, but refused to take this one back.
2. T-60 key, 45x125mm.
3. T-60 bit, 1/2" drive.
4. 2 Pro-comp 6 degrees shims. These are really crappy ones, not steel - I used them for a couple of days. Thank God I needed 8 degrees.
5. Stock u-bolts for 8 1/4.
6. 4 U-bolts one could get when ordering a lift kit from 4 wheel parts
, used them for a few days.
D = 1/2", L = 7 1/2", C = 3 1/8"
7. A few degree washers - I used a couple like these to install hooks for my RE quick disconnects. square 3/4" side, 9/16" hole diameter, the angle is ~9 degrees.
Anybody needs any of this ?
Thank you,
Andrey
Thank you,
Andrey
