Spare 231
BRIANHO13 said:
Anyone in the area got one they are willing to part with?
what do you need?
i blew one up and have the carcas with AFIK everything inside it is good..
Opie, I'll take the planetary reduction parts w/ input gear if you don't mind...
thinkin on making a crawl box? - the case is split hardcore... and the input gear (21 spline short) has surface rust...
the mainshaft, bearings, sprockets, and chain are the salvageable parts... I dont know about the planataries - but like i said, you probably wouldnt want to use the sun gear...
Yea I am looking for a 23 spline input, picked up a dana 300 and was looking at doubling it witha a 231. right now I already have the 4 to1 so I would rather sell that entire case than take it apart.
I'm doing the same thing with a Bronco Dana 20. (Well, I've been thinking about it for at least 3 years, never got beyond the parts gathering stage.) I was just figuring that while I was making that for the '97 XJ I could make another one with a 241 for the MJ when I plunk the 6.2/NV4500 combo in. If you can use what he's got Brian, go for it, you are more likely to git-r-dun than I am.
PS Opie, I ain't skeered of no surface rust.
21 spline is dead to me, go fer it.
XJ_ranger said:
my case wont work for you guys anyway...
the aluminum is split... if it would work i would be using it - i bought a d300 as well :D
oh - and check this out - http://www.pirate4x4.com/forum/showthread.php?t=451754
350 for the parts to make your 231 into a crawler box... - cheaper than the np203 to 205 adaptor...
I don't care if the case is split, I'll make my own. I just need the reduction guts. Gimme gimme gimme!
Yea I saw that in your post from the other day....thanks a lot. Apparently you can also flip the 300 with that kit as well. i guess all thats left is figuring out the twin sticking.
