AZjeepin1
- Glendale, AZ
Jesus Brent, that's super clean. Might have to have your attention to detail help me on my Heep!
that came out really good. never thought about sectioning the headliner. Is the cut in the middle noticeable at all? does it move or separate at all while driving or flexing it out?
Yes, it's noticeable. Probably more to me than anyone else though. The rear half hangs down about 1/4" lower in the middle than the front. I tried to buy some "H-Moulding" online so I could just paint it to match and slide the two halves together. The only place I found any that should fit, I called them and they no longer make it. I went to an upholstery shop and they didn't have any good ideas either. I don't notice it moving around at all though. The body's pretty rigid with the cage. I recently bought a stock overhead console. It's long enough to go past the seam in the headliner, so I'm thinking about installing it partly for the cool factor, partly to hold up the center of the rear half of the headliner.
I used FatMat in my XJ. Similar product to DynaMat, but less expensive. I picked it up on Ebay. I did the floor, roof, fenderwells and inside the doors. When I shut a door now it has a solid "thud" instead of sounding like someone banging a gong. Definitely not as quiet as some newer cars, but it did make a big difference in noise. My A/C works much better too due to the insulating properties of this stuff. That's important down here in the desert.
